- The Design House 783050 Scroll 2-Way Latch Entry Door Knob and Handle accepts a key on one side of the lock but is operated by a turn-button handle on the other side. - Finished in polished brass and designed for left or right hand doors, this handle fits the two most common backsets in the U.S. (2-3/4 and 2-3/8) . - The 1/2 latch bolt is plated in nickel and does not budge once in place. - Entry handles are often used on front doors and back doors. - Use this handle on standard 1-3/8 and 1-3/4 thick doors. - This product has a 1 by 2-1/4 radius corner face plate and 5-pin security. - If you are preparing your door for installation, the cross bore should be 2-1/8 in diameter and the edge bore should be 1 in diameter. - This product is ANSI Grade-3 certified, which means this handle is rated for residential Security. - The Design House 783050 Scroll 2-Way Latch Entry Door Knob and Handle comes with a limited lifetime mechanical warranty and a 5-year finish warranty that protect against defects in material and workmanship. - Design House offers products in multiple home decor categories including lighting, ceiling fans, hardware and plumbing products. - With years of hands-on experience, Design House understands every aspect of the home decor industry, and devotes itself to providing quality products across the home decor spectrum. - Providing value to their customers, Design House uses industry leading merchandising solutions and innovative programs. - Design House is committed to providing high quality products for your home improvement projects. - UL Listed for use on fire doors (3 Hours) . - Entry Lock; operated by a key on the exterior and is by a turn-button knob on the interior. Design House - 783050
